Trunk rubber seal
Buford19
Kitimat b.c.
Is this the proper way that the trunk seal is applied? Know there’s lots of threads on this, but I want to be sure. This is on a 67 barracuda. Thanks for any info that make this clear.
No!
The trunk seal is backwards. The split should face out. When you close the trunk the split will pinch together and keep it water tight.
Riddler
Ok I seen some pictures of the rubber being glued on the lower deck two different ways. Which of the two is correct?
