hcallaway
My question is: What can I use as a sealant between the new base and old base? I plan on using a few rivets but want to seal between the two bases. Is heat going to be an issue? Is gasket sealant a good item?
That came out purdy good bud!I did this last year and its mostly welded...
but I did fill in some gaps with "Oatey Epoxy Putty"
Held up Great!
What intake and carb?I did this last year and its mostly welded...
Held up Great!
That's a Stock Commando Intake from a '65. Carter AFB 500cfm from '65.What intake and carb?
