I second watching fitzees videos!
Looks like you're trying to run a continuous bead.Trying to weld in some floor patches in my 69’ Dart. Using a MillerMatic 251 MIG welder with .030” wire. Can’t get a good weld for the life of me (as you can see). Been trying the whole day. I suck. Blowing holes through the floor. Turn the voltage and speed down and now the weld just piles up in ugly blobs (and still blow holes here and there). Ended up just grinding them down to see what I was doing. YouTubers make it look so easy, no idea what I’m doing wrong.
Would these ugly stitch welds hold though?
Any help is greatly appreciated. I’m so frustrated I want to give up… :-(
Running a contunuous bead will not work. Too much head gererated so warping is a problem. What I would do is find a tig welder for rent and practice. If you must use a mig, approach it as a whole bunch af good, solid tack welds...start at one end, make a tack approx 1/4 X 1/4 and let it cool. Tack the other end while you wait. Rinse and repeat. When all the tacks are combined, as long as you overlapped each one by 1/16, you will have a good solid weld with minimal warping. Don't grind it to make it look pretty, to many people do this and it ends up cracking because the material is so thin. Another thing I've done in the past is place a piece of thicker steel on the opposite side to serve as a heat sink. Just dont blow through the panel and weld your heat sink to the panel you're repairing!Trying to weld in some floor patches in my 69’ Dart. Using a MillerMatic 251 MIG welder with .030” wire. Can’t get a good weld for the life of me (as you can see). Been trying the whole day. I suck. Blowing holes through the floor. Turn the voltage and speed down and now the weld just piles up in ugly blobs (and still blow holes here and there). Ended up just grinding them down to see what I was doing. YouTubers make it look so easy, no idea what I’m doing wrong.
You will need an 0.025 inner liner and use 0.023 tips for 0.023 wire. A 0.035 inner liner for 0.030 wire will not work.Get the proper .023 tips for your welder while your there.
I have found this NOT to be the case. I use a Millermatic 210 and have used both .035 and .023 wire by simply using the corresponding feed rollers and contact tips.You will need an 0.025 inner liner and use 0.023 tips for 0.023 wire. A 0.035 inner liner for 0.030 wire will not work.
I agree. I have been doing welder repair for 30 years. As long as the liner is not too small you are good to go as long as you have the correct tip and drive rollI have found this NOT to be the case. I use a Millermatic 210 and have used both .035 and .023 wire by simply using the corresponding feed rollers and contact tips.
No side breezes, use cardboard and visqueen as wind breaks.
Turn the gas flow up to 25-30 Cf. Go in short 1-2 inch welds.
CLEAN, CLEAN! Clean it again. Rust, grease and paint will wick towards the heat.
Ground clamp within 2 foot of welding and best if in direction you are pushing the tip.
I agree but in 1994 when my Community Collage got in 10 new Lincoln SP175's they all came with 0.035" liners and my Instructor tasked me to convert all them to 0.023 wire. I had 10 new 0.025" liners so it was an easy swap. I also had to have the Collage machine shop make 10 aluminum adapter spools for each to hold the large 10-12 pound spool.I agree. I have been doing welder repair for 30 years. As long as the liner is not too small you are good to go as long as you have the correct tip and drive roll
The weld through primers are not all created equally. I had really crappy luck with the Napa brand zinc weld-thru. But much better with a copper-based one from another manufacture, as well as the zinc type from another manufacture. It’s not cheap but you could try a different type.I've also never been able to use weld thru primer on the backside of anything I've been welding. I can watch people on youtube use it all day long but it is like straight up weld repellant when I try to use it. My welder acts as if it's trying to weld through motor oil if there is weld thru primer on the backside.
