TTI 1 7/8 Race Header Install help
You also could try moving the engine around alitle in the mounts or if possible add a shim to the driver side enginemount, to tillt the engine away from the steeringshaft.
Correct. i would also loosen the trans bolts and see if you could push the tailshaft over a bit. Wont take much.
