Demon_Dan
Hey gang.. I'm hoping you all can help me with a problem I'm having. My 1972 Demon 318 was getting a new transmission put in and they were also going to install a fresh TTI 2.5 inch exhaust . The car had headers and I have gone back to manifolds . All the information I gave TTI was deemed correct and the exhaust "should" fit. It fits fine on the passenger side but does not fit on the driver's side . The steering linkage / pitman arm seems to hit the exhaust when you try to turn the wheel . Until this is addressed , the car is stuck at the shop , upsetting both the shop and me. TTI and the shop are in contact , but I want to see if you folks can tell by the pictures what might be doing wrong . Thanks.
