Snake
Mopar Nut
Just arrived my new TTI head pipes,for the 69-70 hp exhaust manifolds,nice they are.My question is there is no dent to clear the torsion bars,or they made with out any dents,to fit .
For sum reason i saw a pic were tti put a dent to clear the T bars. any else.I put them on a Duster, and I just got another set going on another duster. Yes, I put a small ding to clear the torsion bar. that was it. Maybe I didn't have to, but it was awful close. I suspect I'll do the same on this other set I'll be installing.
There wrap up now,Cindy got them for me for X MASS.Pics?
Nice build you have going on there.
This is true. It still led to both of my dusters needing to have a ding by the driver side torsion bar. Neither were touching, but both just had a sliver of daylight. The engine will lift on that side. One has Schumacher mounts, the other has new mounts from O'reilly's.If the motor mounts are good, and the motor is in the correct location, you won't need to modify TTI's parts. You'd be surprised how far "off" an engine can be installed. All the bolt holes are either slotted or oversize. Combine that with a stack-up of tolerances, and that motor can be sitting "anywhere".
Thanks I have fun building / driving itNice build you have going on there.
