512Stroker
We are all here because we are not all there.
I had this same issue with my 67 Barracuda - 340They are biscuit mounts.
Are the mounts new or are they all clapped out?
https://www.ttiexhaust.com/MoparClassics-Headers/340-Step/TTi340.htm~ Our headers were designed to fit with the engines located to the factory specifications. If the engine is not located correctly in the chassis, the headers will not fit properly. We strongly suggest you check your engine location prior to installation.
~ Due to various manufacturing designs, aftermarket parts, engine configurations, suspension combinations, etc... TTi cannot ensure headers and exhaust systems to fit all combinations. However, we have done our best to accommodate both factory and aftermarket component combinations. In some cases, slight modification or repositioning may be required on your part to clear the specific situation.
No it should help. Because it is step number one, before you even try to install them.I know this wont help, but -----------Its important to have the engine located right to start with !
I like seeing muscle car owners in Europe! I can imagine how difficult it is getting parts.
I was stationed in England 1987-1990 and only saw two American muscle cars. A Camero and a Nova.
I'm sure you get a lot of looks when you drive your Mopar!!
this is the easiest way. This was a 4 spd car with factory clutch linkage. Z bar modifications were required. This would have really sucked putting them in while the engine is in the car.
I've never found any "junk" headers that flop right in an A body. As a matter of fact, I've never found any headers that flop right in an A body.Good headers never “flop right in”. Only junk headers do that.
I find it hard to believe the TTI instructions don’t cover installation.
