1. Joel Chapman
    Joel Chapman Well-Known Member
    162
    18
    Jul 28, 2019
    Mountain Home, ID/ Hughson, CA
    Local Time:
    10:16 PM
    Are TTI headers really worth the money, meaning they aren’t that big of a hassle to install and massaging the headers is at a minimum? Pretty much every other brand has reviews at summit of needing to mod something or bash the pipes. Will buying TTI avoid all that?
  2. Syleng1
    Syleng1 Karma is real and Life is short... FABO Gold Member
    1,880
    1462
    Jul 5, 2005
    North Franklin, CT
    Local Time:
    9:16 AM
    I don’t know honestly having installed a few brands on a body MoPars . It seems the more money you spend - the easier or “better the fit.” My recent adventure of Dougs ceramic coat small block headers in my demon 4 speed was no dents or bending BUT due to the ceramic coating I felt like the whole job I was walking on a tight rope over a river full of alligators. They are definitely “better” than the $150 summit headers - all depends on what you want for results. Balanced exhaust gases.... anything brand headers. Ground clearance- Dougs or TTI is a must. Ease of install- buy a Chevy. Lol!
    • Like Like x 2
    • Thanks! Thanks! x 1
    • 512Stroker
      512Stroker We are all here because we are not all there.
      1,812
      1274
      May 30, 2016
      Freedom, MO
      Local Time:
      8:16 AM
      The answer is that IMO they are not worth the money and are a total bitch to put in. I put a set of long tube small block TTI headers in my 67 Barracuda twice because the first set cracked thru a weld at the head flange.
      In their defense I am not aware of any header that just drops right in an A body mopar.
      You may want to look at a set of Schumacher headers if you can still get them.
      Good luck
      • pntastar69
        pntastar69 Well-Known Member
        1,496
        152
        Dec 28, 2006
        Gilbertsville, PA
        Local Time:
        10:16 AM
        I must have been the lucky one. Mine dropped right in.
      • Kendog 170
        Kendog 170 Let the boy go !
        1,375
        887
        Mar 10, 2016
        Tewksbury Ma.
        Local Time:
        9:16 AM
        Mine fit great 550" RB But, I lowered my body over with them already installed.
      • 318willrun
        318willrun Utube channel 318willrun
        15,536
        16676
        Sep 13, 2013
        I'm here
        Local Time:
        8:16 AM
        Never tried TTI headers. I used their head pipes twice and they fit great. I installed Doug's and I can vouch that they fit much better than the cheapies. I would imagine TTI's would fit better than the cheapies too..... just so much is tied into the car - how the motor sits, and how much of the tolerances the car uses up when it was built
        • Agree Agree x 1
        • fklskv
          fklskv Well-Known Member
          1,184
          628
          Aug 14, 2011
          Lackawanna, NY
          Local Time:
          9:16 AM
          Tti’s slide right in but there is a proper way to put them in. They go in from the bottom.
          You need to remove the center link and or jack the engine up if needed to gain clearance.
          • Agree Agree x 1
          • moparmarks
            moparmarks zippindippintie FABO Gold Member
            1,224
            609
            Oct 5, 2014
            Western Colorado
            Local Time:
            7:16 AM
            Depends on what you need. I used their SB shorties in my Dart cause A, I didn't want long tubes and B, they are the only A body shorties that work with a 4-spd. All others are for auto only.
            I've built a few big Hemi motor Cudas and they have the big ass 2.25 primary tubes.
            If your just building the average street car there are plenty of other options.
            I've had good luck with Hooker Super Comps and Dougs too. Hooker Comps don't fit well.
          • TheGrateRonzini
            TheGrateRonzini FABO Gold Member FABO Gold Member
            822
            675
            Oct 25, 2017
            Western New York
            Local Time:
            9:16 AM
            My TTI 440-200 fit great, it’s everything else that got in the way! Steering column? smash. Torsion bar? Smash! Steering box? Smash! Pitman arm grease fitting hitting header? Smash!
            Everything else fits great now too. Haha
          • 69_340_GTS
            69_340_GTS Well-Known Member
            4,116
            1998
            Jul 11, 2014
            Torrington, CT
            Local Time:
            9:16 AM
            Nope. If the car is out of whack, nothing will fit properly. Get the engine in the right spot, replace saggy motor and tranny mounts, move the column away from the engine, etc... and TTIs fit great! You can easily make, or remove, 1/2" of clearance just by loosening some nuts and bolts and moving things around.
            • Agree Agree x 1
            • Standonit1972
              Standonit1972 FABO Gold Member FABO Gold Member
              130
              168
              Dec 11, 2019
              Atlanta
              Local Time:
              9:16 AM
              I love mine. They are 2 1/4 step headers. They are tough to install but once they were on I had more room than I had with my old headers. TTI knows their stuff, and you will have a minimum of massaging to clear things. I highly recommend them.
              • Agree Agree x 1
              • fklskv
                1,184
                628
                Aug 14, 2011
                Lackawanna, NY
                Local Time:
                9:16 AM
                If you do a search here on Abodies You will get a ton of answers.
              • Howard1784
                Howard1784 Well-Known Member
                661
                96
                Nov 3, 2009
                Rochester, NY
                Local Time:
                9:16 AM
                If you get the TTI's, make note of lubricating them during the off season as per instructions. I found out to late and my $800 headers are now rusting
              • Standonit1972
                130
                168
                Dec 11, 2019
                Atlanta
                Local Time:
                9:16 AM
                I had mine coated, and I would recommend anyone buying them to do the same.
              • moparmarks
                1,224
                609
                Oct 5, 2014
                Western Colorado
                Local Time:
                7:16 AM
                Which ones? Bare, nickel or coated?
              • SGBARRACUDA
                SGBARRACUDA ROY FABO Gold Member
                17,554
                6235
                Dec 7, 2006
                PLANT CITY FL. and PERRY GA.
                Local Time:
                9:16 AM
                The 68 Barracuda in my avatar was a pice of cake using the TTI 340 step header. Of course mine had a complete RMS front suspension. I put it on my 2 post lift, slide them right in from th bottom. Had to install a bolt at the header flange to keep them from falling out on my head.
                • Like Like x 1
                • Agree Agree x 1
                • 512Stroker
                  1,812
                  1274
                  May 30, 2016
                  Freedom, MO
                  Local Time:
                  8:16 AM
                  I fought the drivers side because of the power steering gear box and had to put in new motor mounts as the old ones were sagging bad,
                • fklskv
                  1,184
                  628
                  Aug 14, 2011
                  Lackawanna, NY
                  Local Time:
                  9:16 AM
                  • moparmarks
                    1,224
                    609
                    Oct 5, 2014
                    Western Colorado
                    Local Time:
                    7:16 AM
                    I have nickel ones on my Dart and I painted the insides before I installed. Maybe that will help, don't know.
                  • Fred Scigliano
                    Fred Scigliano Lots of money
                    15,308
                    21094
                    Nov 26, 2017
                    NORTH DAKOTA
                    Local Time:
                    8:16 AM
                    20200117_181900.jpg 20200117_181400.jpg 20200118_142645.jpg Pictures say a lot I think.
                    had to dent mine to clear the steering box and put a spacer on the motor mount. not a thick spacer about a 1/4" . Other than that no problems and good ground clearance, haven't scraped them on a speed bump yet. Expensive but I like my TTI headers.
                  • AJ/FormS
                    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                    19,242
                    7127
                    Jan 19, 2014
                    South-Central Manitoba,Canada, 900ftelevation
                    Local Time:
                    8:16 AM
                    I thought they fit pretty nice into my 68 Barracuda, as well, with a 360/A833/power-steering; just minor (IMO) adjustments.
                    And mine even hold their torque at the flange. I haven't ever had to retorque them.
                    The way I drive, only this style will survive; my car is lowered a bit, and I never have to adjust my style to accommodate them. One of my favorite things to do is, if I get lucky and see a tuner-car crab-crawling over a speed bump; I slap the throttle hard going over said speed bump,as I roar past, trying to get air,lol. Hyup, juvenile I know, but some things are just priceless.
                    I can't say that about the 7qt roadrace oilpan, that only hangs down less than inch, below the K-member. After I smashed it, and had to take it off to clean it and fix it, I finally fabbed up/installed a skid plate from 1/4 inch steel. Yeah, it's heavy, but it's doing the job!
                    And finally, my TTIs were new in 1999. I drove those headers 4-seasons until spring of 2004 or 5. They finally rotted out at the top of the merge where the gravel,snow, and salt accumulate. No big deal for me cuz the engine was coming out every winter anyway for inspection;( and a smoggerteen went in for the winter), I just welded it up. Three or four years later, the other side needed a patch in the same place, and they need attention again. But where are you gonna get an under the steering header that even lasts 3 years in these conditions; Never mind 20 years with minor repairs?
                    Doing the math, those nickel-plated TTIs are the cheapest header per year, I have ever had. I paid 500USd in 1999;
                    500/20yrs=25 bucks a year. I suppose you could buy a cheapie header every 5 yrs, and not have to fix the merges, and come out even, but just try and get a cheapie to go 5yrs.
                    If you figure it as cost per thousand miles, it gets even better;
                    My TTIs have close to 128,000 miles on them.
                    500/128= $3.91 per 1000 miles/ ~39cents per 100.
                    If your $150 headers make three summers and drive 10,000 miles, that comes to; 150/10=$15 per 1000miles/ $1.50 per 100; nearly 4 times as much.
                    And in 20 years you will burn thru ~6 or7 installs....... How much fun is that with under-the-steering, headers..... And you will burn up flange gaskets faster...
                    IDK;I chose TTI's for the road clearance; $500 seemed fair. Bottom line is that I've never been sorry.
                    As I recall, in 1999 they were the only company to offer this drop-in style header.
                    • Like Like x 1
                    • Agree Agree x 1
                    • pntastar69
                      1,496
                      152
                      Dec 28, 2006
                      Gilbertsville, PA
                      Local Time:
                      10:16 AM
                      I also lay 3mil plastic on the garage floor in the winter season. No rust for over 10 years.
                      • Like Like x 1
                      • 65 Cuda 340
                        65 Cuda 340 FABO Gold Member FABO Gold Member
                        211
                        231
                        Dec 27, 2019
                        Tallahassee Florida
                        Local Time:
                        9:16 AM
                        In the fall of 2011, I managed to install TTI long-tube headers and mandrel bent 2.5 inch X-Pipe exhaust system in my 67 Barracuda not long after an extended hospital stay and my left arm barely worked. Easy to install, and best fitting headers ever. And power? Unbelievable how much they helped over the 340 hi-po manifolds I had been running. And this on a fairly mild 360. In fact, I had to start running drag radials on the street because I got tired of going sideways every time I gave it full throttle in low gear.
                        I was so impressed that I bought TTI's for my 65 Barracuda, which has a much smaller engine compartment than 67-up. They were a lot more work to install; had to move things (brakes lines, battery cables, starter wiring and the like), change clutch linkage, shorten the steering column jacket, etc., etc. plus take a BFH to a couple tubes to get everything to clear.
                        • Joel Chapman
                          162
                          18
                          Jul 28, 2019
                          Local Time:
                          10:16 PM
                          Thank you for all the answers! I’ve been looking towards getting some shorty headers from TTI. The engine is coming out while I’m deployed for a full rebuild anyways I figured now would be a good time to try and upgrade the exhaust. It’s going to be rebuilt a little bit beefier then stick but nothing crazy. Just read lots of stories on here bout power steering causing issues with full length headers and clearance issues as well. I saw a set of block huggers on summit but they are center dump and I think I read on here that center dump shorties are not the best?
                        • Howard1784
                          661
                          96
                          Nov 3, 2009
                          Rochester, NY
                          Local Time:
                          9:16 AM
                          Ceramic coated
