kennethjohn09
Active Member
Will this headers fit with Holley gen 3 hemi motor mounts?
Are those the hooker shorties?
If so what oil dipstick are you running?
I tried to fit TTI headers on a QA1 k member with the Holley engine bracket. No bueno. Will have to hack the **** out of the bracket to clear the tubes. This was a mock up on the floor, thank goodness.
Sorry. I forgot to add that this was on E-Body stuff. Point being is different manufacturers parts not playing well together. TTI work with TTI, etc. So, since the Holley stuff moves engine forward, I would think the same issue would arise in an A-Body application.I’m a little confused. The Holley mounts are for V8 spool mount k-frames only and (I thought) the QA1 k-frame was biscuit mount only. Separate issue, just not following what you were going to do.
The hooker shorties are made and sold as part of the holley kit. So yes should work with the holley dipstick as all designed to work together. I have the entire kit just need the sumpAre those the hooker shorties?
Please let me know if the holley dip stick fits and send some pictures. I have those the same dip stick but it doesn’t fit with the holley manifold
