Tubular K Frame Identification
here is cap crap...
Look at their reviews, many comments on failed welds. May want to look at adding some gussets to help strengthen some of those areas especially where the angles are exaggerated, anything welded less than perpendicular is a weak point just through the physics of it all. Look at roll cages that have odd intersecting angles, any reputable chassis builder installs gussets.
That being said if you do your due diligence you should be ok.
What are you running?
THE EARLY MAG. FORCE TUBULAR RACE SET UP -----no troubles w/ it for 10ish yrs, on the street-
just replaced the rack and pinion and outer heim joints on the tie rods -
my success w/ it is probly because the engine is on a motor plate , and not the k frame -------??
