bobscuda67
I want to improve the handling of my car this winter and was thinking about changing the upper control arm bushings to the Moog offset bushings. But would I be better off just replacing the whole control arm to a tubular style to dial in more caster and camber?
My car is street driven only and the alignment is setup to 67 specs.
I also want to change the tie rod adjustment tube to a solid piece and I have a 20:1 worm shaft for ma manual steering box.
