okey specs for car first.
dart 71 318
scat i-beams
kb flat top pistons
comp cams nostalgia plus pn#20-670-20
int.dur.adv 280
exh.dur.adv 287
exh. valve lift 0.474
int. valve lift 0.474
speedermaster intake
edelbrock 1405 carb
mopar elec ign
vac advence is disconnect and base timing is about 20 if i remember correctly
so i got the car couple weeks ago. the pcv from carp was disconnected
so i put in back to carp. it idlesh okayeish but like every 30secs it shakes like crazy. it dosent stay running without gas on cold engine and manual choke dosent have like any effect.
i hooked vac meter to carp it only gets 7-10 vacuum, so i tried to adjust the idle mixture screws and it had very minimal change. if i let it idle like 15mins temps rise to 212f where i shut the car off, it dosent puke coolant. but im not sure if the temps is because mechanical fan is 2inch from rad and theres no fan shroud, i alredy checked to thermostat in boiling water and drilled 2mm hole in it. what i should check next thanks in advance :=)
dart 71 318
scat i-beams
kb flat top pistons
int.dur.adv 280
exh.dur.adv 287
edelbrock 1405 carb
mopar elec ign
