Stats:
318 108k
2 barrel chinese carter bbd clone
Pertronix Ignitor II with coil, I haven't bypassed the resistor yet.
New Plugs
New vacuum advance
Stock single 1.75" exhaust
16.8 MPG on the last 100 mile highway trip driving between 60-70.
My tachometer turns out to be a piece of HF crap and I just tried to set the speed and idle mixture by ear. Set timing with vacuum advance plugged off. The car's spec tag said timing TDC with no number so I set it at idle at 0. I have been chasing a severe miss/cough and die on hard acceleration. It hasn't really improved. It feels flooded a lot of the time, accelerating in neutral seems to clear it out and make it idle better.
I originally decided that the vac advance was the problem, and it was definitely not working, the diaphragm leaked badly and the advance plate was sticky. I fixed that and verified that the advance was working.
I've read through several posts to get an idea of what I'm doing but I ended up being unsure of what I'm doing wrong.
I'm thinking it might be the crappy chinese knock-off carb. it only has 2 vacuum inputs. A pvc on the throttle plate and the other one on the carb body passenger side. That is hooked up to the vac advance.
I know I still need to do a compression test, I failed to do so while changing the spark plugs.
It does the miss/die under load for take off, but it also does it in park. I don't have an air fuel mixture tester but the tailpipe doesn't burn my eyes as much as it used to.
I have a carb kit for the old carter but I snapped one of the idle mixture screws off while getting it ready for the ultrasonic cleaner. I think the throttle plate off of the chinese carb will fit it, I just need to try it.
If you are still reading this, and reading it on Christmas day, Merry Christmas and thanks for any helpful advice you have to offer!
318 108k
New Plugs
New vacuum advance
