moparwedge
Active Member
moparwedge: here's what will need to be done to the carbs. purchase the tops for the vacuum pods that tie the signals together. next get 2 vacuum spring kits and use the black springs in each pod. next 2 accelerator pump cam kits and use the green ones. buy the simplest straight throttle rod and make the stock cable bracket taller so it's inline with the carbs throttle levers.
I have the pods already, good to know what springs and pumps to use. I did spend the money on a good linkage kit. Thx.
