Tunnel Ram Question
Badart
Senior Member
Northern Utah
I'm going old school on my 360 with an Offy Tunnel Ram on my dart. I have two holley 4160 450 cfm carbs with vacuum secondaries that I plan on using.
Here are the engine specs
.030" 360 KB107's
Comp XE284H
2.02 J heads with bowl work and runner cleanup
PRW 1.6 stainless rockers
Hooker comp headers, but thinking about TTis
3K stall convetor
3.91 gears
This is a street/strip car. I know it will be tricky dialing this setup in, but I like to tinker. My question is about the individual plentums. Should I run a balance tube between the two with like 1" arp fittings? Would it help balance the two plentums? Does that matter in a street car? Help me out FABO wizards.
Member, 340 8BBL, "Wade" has dual quads on his set up. He has them dialed in pretty darn good. He can probably help with your questions.
