CUUDAK
CONDENSED PART LIST OF WHAT I HAVE
I don't know if you guys have seen the MadDart build but I Started mine soon after. This was to be a budget build with ebay stuff. My plan was twin Chinese GT45 turbos but could not bring myself to do it that way.
I got the BW S480.
The S480 80mm with upgraded 1.10 A/R housing and .83 wheel is from the clasiffied section in TTF $775.00 shipped, came with 5" V-band clamp and starter pipe and 5" to 4" reducer that I am not using.
Oil feed and return kit from ebay $40 shipped
The JDMSport intercooler is from ebay, nice heavy cast piece. Pressure tested at 30lbs for 2 days. No leaks. The piping and couplers came with the kit for $145.00 plus $50 shipping. I will probably change the couplers later due to them being 3 layer. They look like they will be ok tho.
2- 3" to 4" couplers and 2 4" clamps(Ebay) Don't remember price
Bonnet/hat is a Spectre from ebay at $90 shipped, stud kit from autozone and it too is Spectre.
Godspeed 50mm BOV is from ebay at $68
Godspeed 60mm Wastegate is from ebay at $120 shipped
Hallman BMC is from ebay at $70 shipped
3/8" header flanges from ebay at $38 plus 15 shipping
Ebay header kit(Weld-up) $119.00 plus shipping(JEGS)
OBX T6 flange from ebay $20 shipped
5 OBX 3" flange kits at $30 ea. plus shipping(Ebay)
2- 5" 90's from MadDart $70 shipped
Aeromotive A1000 pump and boost reference regulator $350 from a friend, barely used
Aeromotive 16303 pump controller brand new from ebay $170.00 shipped
3" mandrel u's and straight pipe from local shop $100.00
K&N round filter from ebay $40 shipped
Autometer boost gauge free from my Pops
AEM afr gauge kit from ebay $150 shipped
$100 for 400 block from a friend
440 Source main girdle $275 plus shipping
$396.00 for Eagle H-beam rods shipped from THmotorsports.com
Forged 383 crank, mine
Ported iron 906 heads, mine.
Machine work and pistons-pins-rings-cam bearing, .060 overbore, Unknown $$ at this time. I still haven't got it from the machinist yet.
Fel-Pro gasket set $60 shipped from ebay
Looking for a used Performer RPM now. PENDING!
Scott Brown cam $315.00 shipped
I know there is more that I am forgetting!!
Will be using the 833 4 speed that is in the car. 3.55's in place of the 3.91's in the 8 3/4 now, will get a set of 3.0? soon after.
Still need to get main and rod inserts, they will be Clevite77 hp's, around $160.00
Mopar billet timing set $80
All of this is going into my QQ1 Blue 1968 383 "H" code Formula "S" Fastback Barracuda
Also bought all new rotors-calipers-pads-bearings-seals-hoses to convert it to disc brakes from 10" drum. $331.00
Just ordered all the balljoints, bushings and tie-rods too! $140
Changing the K-frame from sandwich mount to spool type. Had this already!
Then once this is completed I will begin the Body and Paint work. Waiting on AMD to produce some sheetmetal pieces I need that is suppose to be out in early Spring 2011.
I got the BW S480.
