Turbo suggestion
It was a comparison to the milled divider you mentioned in the chevy example
I see - it wasn't a milled divider on the cast iron Chevy manifold: the milling was to form a more even surface for a steel plate/Blower base to sit more evenly on... Didn't realise it could cause a misunderstanding: guess you had to be there.
Cheers again. T
PS remember, like a GOOD woman, its not sucking anymore: its Blowing....
When your talking Fluid Dynamics the whole "Plenium Volume thing " Goes out the window when you change from 1 to another , gawd the science would fill a book.
T
Starting on the hot side looking for a flex pipe. The only one I see are stainless. Do they make a mild steel for 2.25 od and where to get. Thanks
