kkeith1986
I bought this pump for my turbo setup but have decided to not go with a turbocharger anymore. Search for info about this pump across the internet and you will see that it is one of the best oil scavenge pump on the market. It is the turbowerx Base model pump and is brand new. It also comes with the screen filter that turbowerx recommends using to extend the life of the pump.
ASKING $175.00 shipped to the lower 48 States and PayPal only
Here is some info about the pump:
1.75GPM (105GPH) scavenging capacity, it is powerful enough to scavenge oil from two journal-bearing turbos. It will self-prime/draw from over 8 vertical feet, and pump the oil as high as 20 vertical feet. The custom black anodized finned heatsink lowers operating temperature, further enhancing reliability.
Whether the application moves 1 oz of oil a minute or up to 1.75 gallons a minute, 'under-flow' applications are no problem. In fact, the TurboWerx pump may be run dry indefinitely.
This pump will fit inside a 7.25" x 4.0" x 4.0" box. It weighs less than 6 pounds, and includes anti-vibration mounting hardware. It is specified to handle a maximum oil temperature of 300+F, and the power consumption is 12 volts @ less than 3.5 amps. Pump inlet and outlet fittings are standard 3/8" NPT. Also suitable for other fluids, such as rear-end, engine coolant, and water. Not compatible with ATF.
This pump is an ideal economical solution for any turbocharger scavenge application.
