whatadish
Member
still trying to get my turn signals to work on my 64 Valiant convertible. I am trying to find the 12v feed to the turn signal switch. I have the wiring diagrams for the car but I dont have a schematic of the actual turn signal switch. I have repaired my instrument cluster with the lm7805 12v regulator(works great) and have metered all grounds at the front and rear lamps. New headlight switch, new turn signal switch, new 1157's, new flasher. I have 12v @ both sides of the flasher, I assume the turn signal switch provides the 12v feed to the lamps, or does it supply the ground. I have also metered the connector at the kick panel. Brake lights ok, when I turn on the right turn signal with the brake pedal depressed the right rear lamp goes out, nothing on the left side when I use the left turn signal. Pigtailed new gounds at the sockets are soldered to the base and gounded very well. If I had the actual turn signal switch schematic I could test the input and output of the switch. The electrical system is completely un-molested and free from cheap scotch locks and crappy splices, yep metered the firewall connectors as well...all fusible links intact as well as fuses and fuse holders. Any help would be greatly appreciated and thanks in advance.
