67Dart273
I would say you have the area of the problem. Don't make this more complicated than it is. You have an ignition switch up in the column. It has a sort of permanent pigtail that comes off the switch, down and out of the column to the connector. If this connector is showing heat damage, that is surely the area of the problem. It might be "crude" but if you can't come up with a better way, cut the connector and carefully reconnect each wire with crimp splices. It would be better to find something else to use as a connector, so that if you need to pull the column / switch apart, you can do that without more cutting.
