moparmat2000
Thats Dead Sexy !!!!
Just cut a round hole in the hood and make them just as functional as the twin scoops on a dart hood with the two round holes that are what 4-5 in diameter? An non functional scoop is pretty lame. Just to let some hot air out at least.Problem w the "periscope scoops" is they are non functional
Qkcuda Can you see the RH hood mounted signal with those scoops? I have a set of hood mounted signals i am concidering putting on sonnys car, wonder if RH one is visible past the scoop. If not, i am not going to drill holes for them. If they are visible with the scoops, could you making me a template so i can drill the hood in the correct spot for them?This is my old race car with a 75 dart sport hood. On my current car I found a set of butchered cuda scoops and made them functional, using the same rubber rings as the dual scoops on the darts.
Yessir. Something that i can line up with the corners of the hood, that has the correct hole sizes. My sons car has light package. I am assuming hood mounted signals were part of that.
Do you have pics of the wire routing through the hood ?Here are some pictures of the location. I didn't want to try removing them, since they haven't moved in 50 years. Hope they help.
Very helpful, thank you.The wiring runs thru the bracing that angles from the front corners of the hood center of the hood. They then connect to the wiring harness towards the driver’s side of the firewall.
Very helpful, thanks.Here is another picture that shows the wires running through the hood bracing
If possible can you take a side view of where the wire comes from the upper hood into the light assembly. My hood is not the original and would like to get an idea where to put the hole for the little black plastic clips that hold the wire to the hood.Here are some pictures of the location. I didn't want to try removing them, since they haven't moved in 50 years. Hope they help.
Roger that !Thanks.I don't have the car anymore. Those pictures were saved on my computer. Machmeter1 is the new owner and may be able to help.
