Mad Dart
Nothing to see Here!
Well I got the 02 Bungs welded in and made some brackets to hold the back of the exhaust dumps in place and welded them up also. Finished up the TPS wiring and the Distributor wiring with the Weather Pack Connectors. I had to reverse the Polarity of the TPS because it was originally meant to be mounted on the Drivers side so it read backwards.
Started wrapping the exhaust. What you see here took me 3 hours, it is a lot of work, damn! It will probably take me another 3 hours to finish it.
Still gotta make up the Meth line and mount the nozzles. I bought some 4an Braided line with black an fittings so it all matches what I have now. AIS only sells it made up with Blue..... YUCK! Everyone has that color no??
I have at least a few days more miscellaneous work to do before I am ready for the Dyno.
