turbofreek
batcrap crazy racing team
frustated and burnt out. dont want it to deal with it anymore.
411in stroked 6.4 bge block n head g3 hemi
custom turbo cam from bfnyperformance
g3 aftermarket lifter
comp pushrods
inconnel valves
psi spring kit
molnar crank
molnar power adder rods
mahles custom pistons annodized and coated
coated pin tool steel
coat bearings
ritter short intake
holley elbow acufab 90mm tb
holley hp efi with 6.85in pro dash
210lb injectors
ptc ried 2pc glide and converter
strange 9in, 40 spline gun drillled axles
billet strange 3rd member 3.70 grear
strange custom valve double adj coilovers all 4 corners
pt1800 air water ic
jgs gates and bovs
twin s475s turbos from forcedinductions
wilwood brakes
cm tubular k member and arms coil over front with rack n pinion
completely rewired front to back top to bottom
new mt radials pros 275s
all cm cage only a few roof bars short of 25.3 cert cage.
im sure im forgetting a bunch.
illness forces sale. this should be a 4 sec 1/8th car once completed.
needs to get some sensors working, im tired of dealing with it and chasing wires on a fully new rewired wired car. also needs drivers door glass. fell out and shatters yesturday.
50k trade for hemi b body or mid 50s hemi mopar. got be streetable as mine is.
comp pushrods
inconnel valves
psi spring kit
molnar crank
coat bearings
ritter short intake
210lb injectors
pt1800 air water ic
jgs gates and bovs
wilwood brakes
