[SOLD] Twin turbo headers and piping
Matts440
Nampa, Idaho
Located in Riverside Ca
Asking $800
Prefer local pick up since it's all so bulky. Went a different route since these headers dont work on r or ritter blocks. They are headman truck headers, set up for gt45 turbos 4" outlet, will need to space engine 1/4" up due to feed tubes from headers to turbos go between mount and block. T4 flanges, 60mm wastegates were ran when Maddart had his engine on the dyno but not since. I took off some of the header wrap on the one side to see where it was hitting, it's all there just need to reattach. Has 02 bungs on both down pipes as well as support brackets to the bell housing. Just need hardware and gaskets for headers and feed pipe. Downpipe is 4" down to 3.5" the rest of the way.
Also if you have a magnum or the lax heads here are some support brackets that bolt to the head to help support the turbos.
Can add the twin air water intercooler rated at 600hp each, for a little more money, need to upgrade these for my build just for the power on race fuel my engine will make. Here's what they look like, dimensions are from frozenboost.com:
Water to Air Intercooler, 150PSI 12x12.25x4.5, S/S I/O (Type 51)
$600 Piping, headers and intercoolers, wastegates. Intercoolers themselves are $200 a piece new
Okay back to $500 for every thing, exhaust piping, headers,60mm wastegates, air/water intercoolers x2.
If I had to guess due to weight of it all and the bulk of the box, probably $150+
That's why local would be better, that and I'd have to go buy a big enough box for it all lol
Bump, moving in 3 weeks to Idaho so anyone in SoCal around riverside wants to buy it speak up.
