drpreposterous
Hey, guys! Still looking to heal the wound I got from unloading my '64 Dart GT last year.
Possibility 1
'64 Valiant four-door. 273 V-8 with mild cam, 4 bbl, aluminum intake, dual exhaust. Tiny amount of wheel well rust. Underneath is clean as are floors. Pinholes in trunk. Interior needs a little work: I have in mind putting in Scat Procar 1300 series and some aftermarket four-point harnesses or shoulder belts (would need to fab a mounts for the latter).
Already has electronic ignition/distributor and disc brakes/dual mc from a 70s Mopar. Also has electric choke and also an electric fan and aluminum shroud on the radiator. 14" steel wheels from a '76 Dart Sport.
Possiblity 2
'64 Dart 270 sedan. Rebuilt torqueflite. New brake lines, master cyl, fuel pump, lifters, and rebuilt carb. Flawless original seats still under plastic. New carpet, tires. Working original dealer installed AC.
Priced $1K less than no. 1 above, but no disc brakes or elec. ignition/distributor. I'd wanna add four-point harness or shoulder belts, plus the disc brake/dual MC conversion and elec. ignition.
I have about $3K in build money for after the purchase. What are your thoughts?
Possibility 1
Possiblity 2
