[WANTED] underfloor bracket for E brake cable
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
I know we have a lot of guys parting stuff. Need just some small things. Need that bracket for a 64 Belvedere but probably any from any A or B body would work.
Also for 64 FOUR door POST Belvedere, need drivers side front door window guts, as far as glass and tracks. Also glass only for passenger front door.
Thanks all!
Thanks all!
any chance its the same as A- body I have a set of 4 doors with all the guts
I think I have an extra of the underfloor e-brake cable thing. Do you have a photo of which one you need? Mine is about 2x2" with one hoop you would feed the cable through. It gets welded to the floor pan. PM if you think this will work for you.
I have e brake cable guides from a 65 Barracuda
