Stephan D
"PS. Try to seperate the spark plug wires more if you can. it can reduce cross talk."
Good idea, will do!
Good idea, will do!
The sound of the video is a bit misleading, but the idle is approx. 750 RPM in Neutral and 650 RPM in gear, there is a timing label under the hood that says 10 degrees +- 2 degrees at 750 RPM.Idle sounds high, but my ears don't do well on videos. There should be a hose routing decal under the hood. There should also be a decal showing the engine timing. A 1979 only factory truck service manual should also have it. This is a one year only engine/emissions set up.
-----------------------------------------------------------------------Sweet Ride------------------------------------------------------------------------
Stephan, The drop of 100 rpm indicates the engine has less power at idle than it should. It's prob too lean and slightly advanced.The sound of the video is a bit misleading, but the idle is approx. 750 RPM in Neutral and 650 RPM in gear, there is a timing label under the hood that says 10 degrees +- 2 degrees at 750 RPM.
The hose routing sticker is there as well but outdated as most of the emissions stuff is gone, our domestic emissions regulations are quite liberal for vintage cars, not so for current vehicles.
If you have the shop manual, look up the advance specifications in the back of the ignition chapter. Otherwise will need to find someone with a specification card. Maybe @halifaxhops was one for a 79 360 in light truck.There could be a big difference between setting 15° and 10° at 750 rpm.
The air pump is gone. Even with cats, its now useless. I'm more concerned that the check valve is now two way! Really needs to plug that all off. Can put some high flow cats if he wants although maybe they won't last as long. Those things really improved in terms of flow when Fox body Mustang 5.0s came out.What Mattax said;
Those are afterburners. Just exhaust powered, fresh air inhalers, to finish burning any misfires to save the cats. If your cats are gone, then you don't need them.
My other concerns with the disconnect systems is the EGR and the idle stop solenoid.
I'd want to be sure the EGR valve or passage is plugged if the system is not being used.
Presumably the air snorkel vacuum motors are still hooked up. If not that could really choke the air flow, maybe even at idle?
Flaps open full time will work. It's a nice feature when they are functioning but not that important for what you want to resolve.
EGR block off plate I don't know whether that is enough or not. If it is great. There are a number of ways the EGR passages were routed. I don't know them that well and not your 360 at all.
If its a performance pull (not an emissions check which we used to do for state inspections) then you will get the most out of dyno session by having a goal and plans.a dyno run is in the plans
