unilugs
the 67 wagon i just bought has unilug cragars in the rear but it uses a round washer.somehow the wheel must center on the inside of the slots.it doesnt wobble but then again i just bought it and havent driven very far.does this seem right?its a 67 coronet 44 wagon with an 8 3/4...should be 5 on 4.5 right?
I have the same wheels. The wide end is as wide as it needs to be for the 4.5 width and the narrow end is just right for the 4 inch width.
As you rotate the wheel to put on the washers & lugs on, the lugs will center up the wheel. Once tightened, they will not move. I have driven many miles over the years with these to no ill effect.
I have the Unilug Crager SS on my car too. No problems on the fronts but the rears are wore out.
There egg shaped on the bolt pattern diameter so any time I leave from a stop you can hear them clunk.
I'm in the process now to fix it.
