5 sec dart
Active Member
Had a 451 low deck in a Dart. 10.3 CR Bill Miller rods Stock heads with 2.14 intakes .600 roller Performer Rpm 750 carb. 9.5" con. 3.91 gear 28 in tire 3400 lbs 10.90@122
Total badassary.
I think you will be knocking on the door!
Yeah, I believe with fresh 28" slicks, cool night and fuel issue sorted, I'll get into the 12's quite easily. The car was pulling hard when it grabbed traction.
I took the Duster out on the weekend with a fresh set of M/T ET Radials 726/60/15 (28") and the car all day ran 13.1's @ 106mph with crap 1.95-2.0 60ft times and it was spinning the boots every run. Tried a few different launches and the like and didn't work. I've scored a pair of Caltracs for it that should sort that issue out. Outside of that the car went beautifully. Nice and straight out of the hole (except the wheelspin) and was really happy overall except for the times. The new converter and shift kit have made a huge difference too.. Shifting at 6,000 and over the line at 5,800 and it was perfect! Just need to sort that 60ft time out and run again and then time for a 100 shot of gas...
No one wants to add weight to there car. But adding some weight in the trunk behind the axle could make a better ET as well as 60" foot.
They say loosing a 100 pound is worth a 10th(.10) right? If you added 50+ pound in the trunk and you ran a .10 or more better 60'....You are faster even though you are heavy...er.
And! way cheaper then a set of caltracs. Also way easier to install too.
69 Barracuda Fastback - full street trim (tools in back...)
408 with stock W2 heads,no porting and standard valves
Comp 248 solid flat tappet, 10.5:1 comp, TTI step headers.
727 / 3000rpm converter
3.9:1 gears
Stock suspension
11.7 at 115.5mph
3.9:1 gears
Stock suspension
11.7 at 115.5mph
