tsa_035
72 Plymouth Duster
I have a '72 Duster 318 with 11" front disc brakes on a 5x4 bolt pattern. I got this car 12 years ago. The brake lines going to the rear had a nail stuck in it. Is this a normal set up on the front. In addition My driver side hub is longated due to a poor bearing replacement operation. I would like to keep the 5x4 dut to the fact that my 83/4 rearend is also a 5x4 with drum brakes. any input helps. Thank you much!
