upper control arm adjustment
dodge71demon
Indiana
Ok i've switched several a body upper control arms to the bigger ones and never woried about getting them adjusted close (toe).Any easy and quick way to adjust them somewhat close?Or should I even worry about it?
You need to get the front end aligned.....if you don't you'll be wearing out tires and have a problem with pulling to one side or the other. The adjustment on the upper control arms is for "caster and camber". Tie rod ends are for toe adjustments.
This is what I did pull the front arm all the way forward and move the rear all the way back that will get ya close.
