coffeedart67
Replaced bushings on my upper control arms and on one bushing on each control arms was a spacer thing, it was either on both front or both rear bushings(not sure which it is, cause I'm not sure which control arm is which side). Just wondered what the spacer thingee is, and is it important, and should there just be the two. I did put them back on. They are about 3/4 long rings, go on the inside of the control arm on the bushing.
