Upper control arms ($161.18/shipped-ebay)
The link and the one OKLA above you provided has this info quite a ways down the description:
"Does not work with stock 1967 1972 "Small Ball joint" spindles.
Cars using the small ball joint order part # 2071456-R and 2071457-L
Larger ball joint. Only fits cars with drum brakes.
(parts do not fit cars wth disc brackes)"
Just in case no one is reading the whole description.
Dallas
This is the upper control arm kit they suggest to use for an A body with the large upper ball joint "standard mopar spindle kit"
http://www.performanceonline.com/19...AR-DISC-BRAKE-CONVERSION-KIT-SWBKS6274-19537/
http://www.performanceonline.com/63...PPER-CONTROL-ARMS-W-BALL-JOINTS-SET-SCA-U6374
This is the response I received back from Performance online on the control arms:
Without measuring, the manufacture says they are the same as stock as far as thickness. They use Clevite bushings and Suspension Int'l ball joints that are equivalent to Moog.
Lower ball joints are Raybestos.
Has anyone bought or used these control arms?
Just a follow-up on these control arms i purchased. Took 8 days to get here but they were well worth the wait. Really nice arms. Had both sides on the duster in an hour total. No beatin or bustin my butt tryin to get those bushings n ball joints out like i have in the past!! Alignment shop was impressed with the quality of these parts but only time will tell. Parts are made in mexico. Thats the only bad part. Can't beat the price without all the extra work too. See how they ride tomorrow on my way to the car show in ocean city maryland. Good show! 1500+ hot-rods.. Later
