What i have here are a pair of upper control arms that are used on the 1973-76 Mopar A Body cars such as Dart, Valiant,Duster Demon. These control arms are required to be used on 1972 and earlier A body cars when doing a disc brake conversion to the larger 4 1/2 inch bolt pattern B or E Body Disc Brakes or the 73-76 A Body disc brakes.
I cleaned them up of all the grease and grime in the solvent tank, and then soaked them off in a solution of a product called Evaporust, to remove the surface rust from these control arms. You paint them the color, and texture paint of your choice. I will leave that up to you. Very nice sets of upper control arms. One of the best sets that i have come across. Not rusted pieces of junk, from the rust bucket states here in the USA. You can't go wrong with parts starting out here in California, Nevada, Arizona.
This is the very last pair of UCA's that i have. This is it, unless i can find some more, to do my thing with them.
Very nice set of UCA's. This set i found last week while making my wrecking yard rounds. These UCA's in this condition are getting really hard to find.
Before i got ahold of these UCA's, somebody replaced the ball joints with new, but not the bushings.
The bushings were absolutely shot so i removed all four of them.
The ball joints are nice and tight, one more so, than the other, so i left them alone.
You use them as is, or replace them. I will leave that up to you.
I have already did all the hard, dirty, work for you, in my labor time.
Your call, and determination, when you see the parts.
But if you use them, you will need to purchase new grease boots for them at your parts store, or Energy Suspension sells nice parts.
$140.00 For this pair of UCA's with the installed ball joints.
+ FEDEX'ing with insurance, and signature delivery, + 4% Pay Pal fee.
I'm not interested in any "trades" or "offers" other than my stated price.
Serious buyers, send me a pm, and we can go from there.
Thank's a lot.
Jim V.
To keep from getting any more questions, how much $$$$$$ to send to zip code XXXXX i will send these UCA's out by USPS flat rate box for $26.00 in the continental USA, with a signature delivery on the package.
So you do the math for the totals.
JV.
Thank's a lot.
Jim V.
JV.
