[SOLD] Used Comp S/S rockers
Mtn Thunder
Tehachapi
For sale is a used S/S roller tip rocker arm set from Comp Cams. Shafts and rockers are in good condition with 4 new adjusters. The shafts show some galling in the hold down area but cleaned up with some scuff pad. They were used with stock hold downs and appeared to move around some. The material removed was aluminum so the shaft was not damaged.I would not use these with stock hold downs.
Price shipped in the lower 48 is $240. Shipped from Tehachapi Ca. 93561
The adjusters are for ball and ball pushrods.
