Dart 67
Active Member
Still waiting for those spacers...
The Chrysler wheels "should" fit fine on the dart, we didn't have any clearance issues. We've put several style chrysler/charger/magnum wheels on different cars because they're cheap, and look good IMO. But the Magnum wheels we always had to mill out the center to clear the hub. The inside diameter were too small. But on the 300C wheels that we got worked just fine, no clearance needed, but we did have to make some center caps but they were easy.
Got these wheels for $300 bones with brand new tread on them.
Thanks!
The rims in front were hitting the hub of the rotor. Spacing them out prevented that.
Rim width, I believe, is 8'', and I have absolutely no idea what the offset is...
And nope, I'm running the bone stock rear axle that came with the car, which I'm pretty sure is a 7 & 1/4''. (It might be an 8 & 1/4'' though, I don't remember)
pretty sure 7 1/4 rears were 4x5 bolt pattern. your is almost certainly an
8 1/4 rear end which i think is a little narrower than an 8 3/4. if you ran a
8 3/4 from a B-body the wheels would be centered nicely in the wheel well.
they look good !!
My 5x4.5 rear end out of a 73 duster is a 7 1/4. It was a disc brake car so it had the 5x4.5 pattern but still only had a 7 1/4 rear.
That looks good though, what size tires are on that 67?
