ramhemi
Member
Longgone said:The seal # crossed over to a 16743 and it fits! Yes it`s a tight fit but the grease is in and the elements are out. Thanks grim, here`s a couple pics of the rotors on.
Where did you get the seal?
ramhemi said:Where did you get the seal?
Longgone said:Napa Auto Parts has the seal or the # could be crossed over to something your local parts store can get.
ramhemi said:Rotors also?
69 DART"420" said:GOOD TO KNOW THANKS FOR ALL THE HARD WORK I WILL B DOING THIS SOON :thumbup:
Dusterb318 said:As for the rear studs....I just got 1/2" replacments for my stock axles....the knurl is the same on the chrysler studs .....
Longgone said:That`s useful information. When I had my axles redrilled for the 4.5"bc Moser threaded in the new studs to save material on the axle.
OldVart said:John:
Do they spot weld the inside of the screwed in studs so they don't back out? I'm assuming they do....
Longgone said:I`d suggest for anyone doing this, take your original rotors (or at least one)with you so that your machinist can use them as a guide.
ramhemi said:That is good idea.Is the seal bore a stock measurement as well?
ramhemi said:Will this work on a 1970 Dart?I can get the KH brake from a guy.
HemiPar said:Hey Longgone. you said that we just need the rotor right? Or do we also need the hub off a mustang? The pic you have shows the hub and rotor. Just making sure. I would like to do this but want to get everything needed. Thanks
Jeff
69 modtop said:i would like to put out a huge thank you to longgone and everyone else involved for doing the legwork on this upgrade and figuring out what is required to do this mod. I just finished it and it worked out awesome. thank you so much again. you made my life a lot easier, cause i'll be the first to admit i'm a little lazy when it comes to figuring these things out. :headbang:
I was told one could also use a 66 B-Body rotor as they were BBC K-H systems anyone know for sure. Althou this seams like a more viable solution as there are more mustang parts suppliers.
Hey Guys, Check out www.brakewarehouse.com
I just bought mustang rotors for 124 shipped.
I also have previously bought the 4" bolt pattern rotors for $69 a pair shipped to my door. I have had good luck dealing with them so far & couldn't beat the prices anywhere else.
Thanks for the reference to this site John, can't wait to get the manifolds from you & try out the rotor swap on my 69 383 car.
The specifications for the mystery seal are as follows:
O.D.- 2.506
I.D.- 1.730
If you know of any seal that fits these specs please post it here. Thanks- John
Width -.250
