QuarterHorse
Yay for me, I start working on it tomorrow!
EvilScamp said:Did that to mine about 2 months ago,not as bad as i thought it was gonna be.
Just watch your cuts when notching the frame,make sure they are straight!
A quick tip: the tube they give you for the rear hangers is a little wider than the frame,i welded a washer to each side of the frame and then to the tube it will give that area of the frame a little more strength.
