jw97neon Well-Known Member Joined Sep 10, 2013 Messages 459 Reaction score 468 Location utah Nov 27, 2015 #1 i have a 65 dart with a 273 and a 64 dart with a slant in it. i am going to take the 273 out the 65 and and put it in my 64. i was wondering do i need to swap k members as well? what are different between the two?
chryslerfat Well-Known Member Joined Aug 23, 2008 Messages 16,054 Reaction score 21,714 Location Monroe,Michigan Nov 27, 2015 #2 K members are the same between /6 and V8 the only difference is the 65 and 66 was factory drilled for a sway bar.
65 Dartman 1 of None 65 Dart Sedan Delivery FABO Gold Member Joined Sep 24, 2006 Messages 13,741 Reaction score 4,582 Location Strasburg, VA Nov 27, 2015 #3 Just keep the 65 motor mounts with the V8 and it will drop right in the 64.
jw97neon Well-Known Member Joined Sep 10, 2013 Messages 459 Reaction score 468 Location utah Nov 27, 2015 #4 sweet thank you that is what I was hoping to hear.
K kesteb Well-Known Member Joined Feb 6, 2015 Messages 343 Reaction score 155 Location washington Nov 27, 2015 #5 You also need the v8 center link from the 65.
AJ/FormS 68 Formua-S fastback clone 367/A833/GVod/3.55s Joined Jan 19, 2014 Messages 25,077 Reaction score 12,419 Location South-Central Manitoba,Canada, 900ftelevation Nov 28, 2015 #6 Are they both pushbutton automatics? Do they both use the same type of carburetor control?
