Bfrank
Member
I am attempting to reconstruct a v8 spool mount k member driver side engine perch. Is the perch on the driver side approx 6-7mm higher than the perch on the passenger side. Is that correct? I'm pretty sure I can still see the original location where the mount bolts sat..most of it has been cut out...but not 100% sure. Also is the driver side perch about 1/2 in farther forward than the passenger side. Thank you for any input!
BF
BF
