VACUUM PUMP QUESTION
WAYNE0
milton pa.
A friend of mine is getting his engine built and was told by the builder that he will need a vacuum pump for his brakes so they have enough vacuum. Is there a certain distance the vacuum pump has to be from the brake booster ? He would like to mount it in the trunk. Would that be to fare away ?
that doesn't sound good. You need it to be close enough that drop in the hose is not an issue, and you are talking about very low pressure, so losses will be high. Vac pumps are not very heavy, or large
I have mine in the trunk and ran plastic tubing to the booster. Hardware stores usually sell it by the foot, No issues at all.
My builder told me that too, for a 292/292/108 cam, into a 360.
and he was right in as much as the 69 dual-diaphragm booster was lazy. But before I threw in the towel, I bolted on a booster off a late 70s F-body.
The idle vacuum of the 292 cam was pretty low, but the F-body booster worked pretty good. It only took a blip on the throttle to charge it up. By the time I had backed out of the carport, and idled off the yard, it was fully charged.
My car is a stick, so I installed a Line-loc to be a hill-holder, so I never have to pay attention to the idle vacuum anymore, while stopped at a light.
Because it's a stick, and I downshift when coming to a stop, the intake vacuum is always high enough.
The only time that the booster gets lazy, is when I'm idling around the parking lot at 500/550 rpm in first gear..... but since it's under 4mph, I don't even notice.
And finally, by 900rpm the vacuum is sufficient to charge the booster.,
So, with this knowledge, I know I can go up another size in cams at least before it becomes a thing.
The point is this, you may not know that you need one until you roadtest your combo with whatever you got. But I will say that the dual-diaphragm I had was lazy. Since it is field-rebuildable, I took it apart ...... and there was nothing wrong with it. So I mean, your results may vary; but I don't recommend one of those. I found out, years later, that others had had the same experience.
He already got the master cylinder/booster combo. Its what the car came with so thats what he wants.
