Newbomb Turk
So basically the average dude should restrain from adding too much CR.
You’d have to be pretty well below average to not figure out how to do it.
Said another way, so easy even the average can do it.
All I can add to that is, If I can figure it out (and I did) a chimp can do it.You’d have to be pretty well below average to not figure out how to do it.
I'd believe you'd be considered way above average, especially since you help the average guy on the regular here.All I can add to that is, If I can figure it out (and I did) a chimp can do it.
I think you give me too much credit, but I thank you.I'd believe you'd be considered way above average, especially since you help the average guy on the regular here.
Or the average dude should read and ask a lot of questions and then try and tune and learn what he can. If he doesn’t he will never be able to be anything else other than an average dude.So basically the average dude should restrain from adding too much CR.
I think I’d take a few steps before I jumped right into how much cr I could get away with.Or the average dude should read and ask a lot of questions and then try and tune and learn what he can. If he doesn’t he will never be able to be anything else other than an average dude.
That sounds like a good plan!I think I’d take a few steps before I jumped right into how much cr I could get away with.
With my if I ever upgrade the short block on my 380hp 5.9l crate I wouldn’t shoot for the stars, I start with a cr that’s generally known to work for the combo, and still might shave off a few decimals just in case.
I have no immediate plans but at some point I’d like to see what I can get out of the magnum heads 1st and go from there, would like to pickup a roller 360 and zero deck with forged pistons. I want to keep the magnum short block stock, it barely has any miles on it.That sounds like a good plan!
Do you think you would keep the factory heads, or upgrade at the time?
I tend to like AJ's build posts because he can run the numbers methodically and can tell what works with the current engine building goal posts. I wanted to find out if those goal post have been moved, and if so, how we can put numbers to it to quantify.
What are chimps and average dudes figuring out?
Read what, and ask questions to who?
That is what I have asked here for someone to post their unicorn build that is running 195-200 psi on the street with pump gas and cast iron heads. Is the ignition severely retarded, cam timing?
The only advice that has been given so far is increase the radiator size
It's like anything else. Welding, drilling and tapping and on and on. My attitude has always been if you are going to own an old vehicle, you need to learn to work on them yourself. It's not like it's a big mystery. The ones that get me are those who cry about having to buy a special tool, use it once and then sell it. Or rent it. If you have plans to keep the vehicle, then keep the tools. I have well over forty years of tools accumulated in seven boxes and in various blow molded cases. Maybe overkill for a do it yourselfer. I did do mechanic work for a living, after all, but nonetheless, I don't get rid of tools. I bet cavemen didn't sell their flintrocks.Or the average dude should read and ask a lot of questions and then try and tune and learn what he can. If he doesn’t he will never be able to be anything else other than an average dude.
Sometimes the old adage "if it ain't broke, don't fix it", goes a long way. Now Daddy, for instance, took it to the extreme. With his 65 Falcon, rather than change the oil at the correct intervals, he'd just add in another container of STP Oil Treatment. Yeah, after twenty years of THAT, guess who had to clean it up and build it?I'd try what you got, why spend money, if not happy once setup right then think about possible swaps.
