I’m ignorant about early A’s. I need a front valance for a 65 Valiant. I understand 63,64 and 65 are the same. BUT is a Barracuda Valance the same?
No, Barracuda valence is different, but a 65 Valiant front valence will fit a Barracuda. Difference is that the 64 and 65 Barracuda valence has - not sure what to call it - a sheet metal insert (?) on each lower corner, viz:
The insert SHOULD be painted black, but most you see these days are body color.
I put a NOS Valiant valence on the front of my 65 Barracuda (very hard to find a good original, as they would bend if you looked at them too hard). It has a full opening, with brackets for the parking lights (which I just bent down out of the way), which on 64-5 Valiants are located within the valence. Since the inset portion of the Barracuda valence should be painted black anyway, it's not too obvious that my Valiant valence does not have the inset portion but is completely open.
64 and 65 Barracuda valences are the same. I think 64 and 65 Valiant valences, while different from Barracuda valences, are also identical to each other.
63's are different, as the valence is not a separate piece but is part of the whole grille panel. Also, the parking lights are on the valence, inside chrome plated shells, viz:
