sshomer
Does anyone know of an after market supplier of early (64 Valiant) A-body spindles? I've got a set but the bearing journals are pretty worn. Any help is appreciated.
Sounds like a great time to upgrade to disc, you can probably find the whole front disc setup cheaper than aftermarket spindles that just keep your drum brakes. Just MHO.
spindles on the way
I had said a day or two and right on time,glad I could help :cheers: should be to you in 3 or 4 day's
