twayne24365
i have a valley cover id like to use with separate intake gaskets rather than the valley tray commonly used, hughes engines details the assembly with factory heads and with the cover and heads in place you seal the intake gasket to the tray with a bead of sealer the length of the gasket which covers the notches in the cylinder heads, then install the intake, how well would that hold up? has anyone used a valley cover with stock heads? thanks
