Valve Cover Spacers
topside
Member
Rating - 0%
0   0   0
New Product: Valve cover spacers
Now you can run roller rockers under your stock covers without having to cut them up or modify them for clearance; also works in cases of intake/cover interference.
Spacers are .187 (3/16") thick aluminum; you can bond them to your heads or covers or double-gasket them as you see fit.
$66/pair to your door in the US, $68 in Canada.
SB LA-style are in stock now, BB are in production.
Best to PM me check, Money Order or PayPal.
We also make .015-thin B/RB intake gaskets that absolutely cure oil/air leaks the first time, as well as a line of automotive tools with a lifetime warranty:
height mics, valve-spring testers, leakdown testers, ring filers, rod-bolt stretch gauges, oil filter cutters, Holley inlet-fitting wrenches, Stromberg jet tools, and the best rearend setup tool on the market. You can see photos & customer feedback on Ebay, seller name topside340.
If I had at least 10 paid orders, I'd do it. Problem so far has been guys "ordering" and then I'm upside-down on the project. Otherwise, it's about $150 to do the CAD and tool up 1 piece.
