71Duster
Checking the adjustment on my valves in the 340. It has a Hughes #HEH2328AL hydraulic cam with crane gold rockers.
On the cam card it reads .000" Valve lash Hot
On the Hughes website under the install directions it reads: "Hydraulic lifters should have approximately .040 to .080 lifter
pre-load, (1 to 2 turns on the rocker arm adjusting screw)."
Heres the link. http://www.hughesengines.com/Upload/productInstructions/New_Camshaft_InstructionsMar2010.pdf
Not sure how to set this correctly.
