changing valve springs and rockers on indy360-1 head , indy to t&d rockers.
what would everyone reccomend as best tool to remove the valve springs with heads on motor ??
Here's one specific for Mopar small block shaft's COMP Cams Shaft Mount Valve Spring Compressors 5323 One guy had an issue. May be not designed for on the car.
This^^^^^When changing springs and such in the car I like this compressor from Advance Auto, or Napa.
I start the piston I am changing the springs on up towards TDC and then feed about 24 inches of 1/4 nylon rope into the cylinder through the plug hole.
Then bring the piston on up until it stops against the rope.
This holds the valves up without blowing all the lube out of your rings and piston.
Using a compressor like this and the rope you don't have to mess with the air.
(I like to lay a piece of old sheet or something like that around the valve I am working on to catch locks from possibly escaping down into the block.)
This ^^^^^ is the one I use for an assembled motor. Very easy to use, and fast...bolt it down and you can do intake and exhaust on one cylinder without removing it.Same tool, cheaper from Mancini...
Proform Valve Spring Compressors, S/B Chrysler
I have one for a BB and it is great.
Summit is even less $$, I have this tool and it works great on SBM dual and single springs.Same tool, cheaper from Mancini...
Proform Valve Spring Compressors 67460
AJ! Add a cheater bar, (hollow tube) as long as you need to increase the lever and up the ratio. I have one of those as well. I like it BUT those stiff performance springs can be a bear without the cheater tube.View attachment 1715241323I have used this one to install Hughes 1129 springs. It's a bit awkward, time-consuming,and underpowered as to lever-ratio, But I made it work.
