some of the MP valve springs price has gotten stupid....
This is the recommended spring from Mopar. Get the recommended spring.
http://www.summitracing.com/parts/DCC-5249848/
18 dollars x 16 springs...$288 dollars for a set...as i said..MP prices are stupid..
What are the rpm specs for this cam,mrmopartech
Crane 99838s.
If you can still get them.
I'm running 924's on a .518 lift mech with a fairly steep ramp, no float at 7000rpm, and I saw someone is selling a set in the mechanical parts for sale section
They are still available. They are a bit stiffer than the ones I was looking at. Have you run these for an extended length of time without issue? Thanks.
im running that cam in my 360. If i remember correctly the springs were 140 at seat, and i remember for sure that they are 350 at max lift, with coil bind just after that.
