Valve springs
66signet
Omak Wa.
What valve spring for Mopar Performance P4120231. It Is the 284* and .484 lift with 1.5 rocker arms. I will be running 1.6 rocker arms which should be .516 lift. I'll be using j heads but will be going to aluminum heads if the 10.9 compression is to much for cast iron heads. I don't see any formulas online to select valve springs. Thanks
Not a lot of options that don’t require modifying the heads.
If the heads are off and that can be done, then the Comp 995-16 is one choice.
